i have had the aspire sway bar from when i stripped the aspire at the yard. it was sitting under my house collecting dust and i decided to put it on the other day. the problem was that i have the gm25r tranny with the hydrolic clutch and it was in the way of where the sway bar goes. so i decided to flip it.
the only problem on the install was that i had to cut a notch out of the crossmember. i had no problem doing this as there is a piece of 3/16 plate welded on top of the crossmember right above the notch.
