Has anyone use this tire size before? I have to replace my tires (185/60/13), they look like slicks right now, they rub a little when i turn. Im thinking this 175/50R13 tire size would solve the problem.
175/50R13 Sumitomo HTR 200
They'd be a little smaller than stock 12's, and if you can find that tire size somewhere cheap i don't know why they wouldn't work.
-Aspire brake swap COMPLETE!
See if you can find a 175-60-13. They'll be almost the same diameter as stock. I ran with that size in a Falken tire and had no rubbing issues at all with lowered suspension.
CheersIan
Poverty produces creativity
