Konig Incident wheels
  • Konig Incident wheels
    Well, my plan was to replace my tires on my wheels (AR24 13x5.5) that i always had since 01. During the weekend I found and bought a 97 aspire, and doing the break swap as we speak . This are the rims I want to buy , but Im confused with the Offset. I checked out the links but still dont understand it. I just want to make sure they fit. Please help? Its been over a year 1 since I driven my Festy and this is the last thing i need to get back on the road. I have the festiva KYB GR-2 strutswith FMS Sport Springs on the car also.
    Konig
    Incident
    Part #: 1N64D08386
    Wheel Size: 6x14
    Bolt Pattern: 4x100
    Offset: 38
    Finish: Graphite_machine_face
    38 offset is +38mm offset... check out this link to understand it:
    Premium domains add authority to your site. Transparent pricing. 1 year WHOIS privacy included. 30-day money back guarantee.
    you likely will need spacers for that setup, as 6" wide wheels.. i'd guess close to 0.300".
    update your profile for location! those are nice wheels!
    -Aspire brake swap COMPLETE!
      if you use the aspire rear struts, you shouldn't have a problem, but as EJP suggests, a spacer in the rear would be better. currently i'm running 14x6 (+35) on 185/60s and rub very little (hard corners). i'm using festy spec KYB gr-2 all around. if you can find 185/55 tires, you won't have any issues, especially if you use the aspire rear struts (no spacer).
        I have 14x6 wheels with 38 offset and have no trouble or any spacers. And the car is lowered.
        93 GL modyfied!!!
        :fish:
          14's should fit no dramas. I have personally used offset +33 to +40 - so with 38 in the middle?
          Nice wheels too!
