what springs and where
  • what springs and where
    where sould i order lowering springs from.i havent found any goo sits yet.i just got my first 93 festiva and love it.i just need to make it fast and handel well....better that stock anyways ..thanks guys
    or you can cut them like me
    -Aspire brake swap COMPLETE!
      lol no
        thanks for the site.i like it
          im looking for a coil over type like the civic ones on ebay.i herd they fit
            but they feel like POO (way too much spring rate)
              Festyboy is right they may actually make you poo if you hit a pot hole, they are very very stiff.
              You could buy some better ground control coilovers I believe, to get a better spring rate.
                well i dont like poo so i think ill go for the fms springs.thanks guys
                  check out these, they seem decent for the price there for a escort gt but im sure they should work too.
                  K2 Motor is your source for premium auto accessories, headlights, tail lights, cat back exhausts, and more for a wide selection of vehicle makes and models. K2 Motor is an official retailer of Spec-D Tuning
                  also look into dropzone coilovers they make a set for the 323 there about 100 bucks and have a life time warranty. I ened up buying a set of the dropzones, and thats what i plan on using with a diffrent spring weight
                    FMS springs are basically shorter stock springs. They may be a bit stiffer but not by much.. -Kyle
                    Cosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
                    White 1990 Ford Festiva - B6 SOHC powered 50 shot = 14.5 @ 94 mph Gone but not forgotten
                    Proud member of Chicken Mechanix Racing
                      Dropzone are generic... all thier springs are around 500# ... decent coilover-bodies but you will have to get new springs from ground control...
                        i just want it to handle well..i also drive it daily as a delivery boy
                          festivamotorsport springs are proven. Slightly lowered ride and comfortable while being sportier than stock.
                          BP powered 91 Festiva L
                          -FMS springs, GR2 struts, Toyo T1R 195/45/14 on Swift GT alloys
                          -Trunk mounted gel battery
                          -Suzuki Swift GT seats, Grant GT steering wheel, auto-locks
                          -Blaupunkt Melbourne deck with Bluetooth, sealed single 12" sub
                            If you want coil overs, buy a kit, toss the (ultra stiff) springs and get some QA1's from Summit. They have a large selection of spring rates. If you're using KYB GR2 struts, skeeters_keeper recommends 150 lb front and 125 lb rear.
