I have some bad news on this guys. I measured up the 323 spindle and they are quite a bit different from the Festiva in a couple of spots.
The distnace from the ball joint pinch bolt to the lower strut bolt is 6" on the Festiva vs.
just over 7" on the 323. The distance from the tie rod hole to the centerline of the axle is 1" greater on the 323 than on the Festiva.
The spindles will physically fit but the car would ride higher and the steering geometry would be off.
Oh well.... maybe I'll have to do the Aspire swap after all.
Poverty produces creativity
