Festiva / Aspire custom info *please read before you post*
This is a sticky topic.
  • Festiva / Aspire custom info *please read before you post*
    This is a page with the basic information that is asked a lot so make sure you look over it to make sure you aren't asking a question that is answered here.
    Link to topic about wheel bolt patterns(has lists of which cars had what)
    http://www.fordfestiva.com/forums/showthread.php?t=90
    Also a link to a tire size calculator remember that the stock Festiva wheels where 165/70 12's
    http://www.miata.net/garage/tirecalcold.html or http://www.miata.net/garage/tirecalc.html
    link to a page about offset of wheels
    http://wheeltool.com/info/offset.html
    Link to Wil's article on proper brake break in procedure as well as drum and rotor resurfacing and how to correct the e-brake freeze.
    http://www.fordfestiva.com/forum/viewtopic.php?t=4033(dead Link)
    If you can find anything else helpful please post a link with a short description. I hope this helps you guys out with some of the more common questions.
    If your question wasn't answered here it might have been already just search the forums and if you can't find it post your question. This just helps to reduce clutter and to reduce the amount of questions that are answered over and over again. Thank you for your help in making my life easier.
    the blue b6-ze oh yeah!!
    Ok, guys, I am working on updating some of these links. So far the first, second, and last link works. I will try to find some good links about brake swaps.
    link to Stevo's rear disc brake swap on the old ezboard. Alot of good info.
    http://p074.ezboard.com/ffordfestiva...tart=1&stop=20
    Abe's capri front hub and brakes install (There are pics on the second page and more information there.
    http://www.fordfestiva.com/forums/sh...=2265#post2265
    More front brake discussion
    http://www.fordfestiva.com/forum/viewtopic.php?t=602
    springs, shocks, and ride quality and lots of really useful info
    http://www.fordfestiva.com/forums/showthread.php?t=9859
    The Festiva Store
      I get a dead link on the "aspire brake swap" thread
        here is another place to get the aspire swap.
        Aspire brakes http://www.clubprotege.com/wil/howto/aspirebrakes.htm
        Tire size calculator which is better than the ones above
        http://www.1010tires.com/TireSizeCalculator.asp
        Offset calculator
        http://www.1010tires.com/WheelOffsetCalculator.asp
          DIY wheel alignment thread:
          http://www.fordfestiva.com/forums/sh...ad.php?t=14004
          -Aspire brake swap COMPLETE!
            I'm getting a dead link on the wheel bolt patterns.
            ENFORCER - Midwest Festiva Inc., Iowa
            #2 .....Cheesehead
            #3 '91 White - Donor Car
            #4 .....Montana Project
            SOLD----Levistiva for $1500
            Bought her back for $450
              I would lreally like to see some of the dead link items in this thread.
              Rodney
              1991 FI 5 Speed Aqua Blue
                what can i put on my 92 festiva for a bigger and wider rim and tire combo?
                  bad question.
                  use the search button.
                  87 rx7
                  92L starsky and hutchstiva bp swap, aspire swap, side pipes(tranny swap on the way)
                  94 caddi deville
                  99 f250 LD 4x4 12 inch lift on 38s
                  i need more festies.
                    That might be but what about those dead links......
                    Rodney
                      There are numerous....and I do mean numerous...other links and discussions that are ver y recent on that subject. All you have to do is look....ohhhhhh MONSOOOOOOON....LOL
                        Here is a link to find lug and bolt pattern for any vehicle:
                        http://www.discountedwheelwarehouse...._Reference.cfm
                          great
                            also for how to measure lugs:
                            http://www.stylinconcepts.com/images/boltpattern.html
                              The emergency brake fix link is broken. I have been searching the website for it but the only thing I have really found is to make sure the arms that go into the hubs are free.
                              Thanks in advance.
                              :festiva::newb::festiva:
