Brake upgrades. aspire? capri? something else?
    ^^ i was just gonna point that out too. Also using the aspire LCA's for the front does require you to use the aspire axels because it is 1/2 to an inch longer.
      No it doesn't Wes. if you're using the Capri swap, you need the aspire LCAs because the festy axles are "too long". the "backspacing" of the Capri knuckle is .6" shorter than the festy's so you use the aspire LCAs to push the knuckle out to make up the differance.
