I just installed the contol arm bushings which are made by Super Pro. They cost me $46.00 for the pair. They fit perfect. The white stuff around the edges is the grease which came with the bushings. I also got the polyurethane swaybar bushings $34.00 and swaybar to control arm bushings $33.00. They were shipped from Australia for $22.00.
SuperPro polyurethane control arm bushings
This is the website that I found the part numbers at. I couldn't find a place online to order them from. I went to a local shop JE Import Performance which is a Tein distributor and they special ordered the bushings. It took 2-3 months because they were shipped by boat in a cargo container. The swaybar bushings are taller than the stock bushings so they are not a direct replacement (I'm getting spacers made and will add a new post with pictures after they are done). The swaybar to control arm bushings look like they will work, will post them when I install them. Here is a link for JE Import Performance:
