Brake conversion
  • Brake conversion
    Could you convert your rear drums to calipers and if so what would be involved in this
    I found this a while ago while searching the forums
    Well, I am about to start the conversion on the snot green 92 Festiva LX, I will take plenty of pictures for all to see. Every so often, I will post u
    -Josh R
      does anyone know is that a egt hub on a festiva spindle?
        yeah, but it's modded
          anyone know the specs on that bracket
          87 rx7
          92L starsky and hutchstiva bp swap, aspire swap, side pipes(tranny swap on the way)
          94 caddi deville
          99 f250 LD 4x4 12 inch lift on 38s
          i need more festies.
