Well im keeping the car and have decided to do the aspire swap. I got the complete rear suspension from an aspire, front knuckles and calipers and the sway bar. I ordered new aspire lower control arms inner and outer tie rod ends 323 kyb gr2 front struts and kyb oem aspire rear struts and will be sitting on civic coilovers. Today i got the front and rear suspension pulled out and just waiting on the new parts to come in the mail ill post up some pics asap. I cant wait till its finished so i can go run the autocross events.
supercar fast now supercar handling
can not find the answer....are you sure you need the Aspire LCA's?...I thought you still needed to use the Festy LCA's and just changed to the Aspire or Escort (for price) tie rod ends"FLTG4LIFE" @FINALLEVEL , "PBH"
I'm pretty sure that the Aspire LCAs are longer than the Festivas. Where did you find the Aspire LCAs by the way?Last edited by fastivaca; 08-08-2009, 12:08 AM.Ian
- Unknown
- Quentin Crisp
- Bumper Sticker
ok so what I remembered is correct....the Aspire is longer. In an auto-x car it may not matter to much but on a daily driver will it not throw the struts out of whack causing tire wear and steering issues?Originally posted by Biglay5150 View PostMy auto-x car has Aspire lca's just make sure you use the Aspire axles too."FLTG4LIFE" @FINALLEVEL , "PBH"
I'd just use the festiva LCA's
How much camber do you gain?Festiva: Because even my dog can build a Honda.
yeah make sure your axles are proper length with those. when i did my no-crossmember tweak to get my motor lower the first set of mounts i built were too far to one side and liked to pop the drivers axle loose around hard cornering.
Some recentering fixed her but still sucks to be stranded on the side of the road on your maiden test voyage because an axle popped!1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
^ yup.-Greg
Redneck Engineer
FOTY - '09
