Does anyone have a source for cheap hub eccentric spacers? I have a set of 13" Dodge Colt wheels that fit the Festiva perfectly except the center hole in the wheel is larger than the hub of the Festiva. If I run them this way, all the weight of the car will be on just the wheel mounting bolts.
Hub Eccentric spacers
Yeah, just put them on and see what happens. Should be fine. BTW the term is "hub-centric".90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
that center bore being larger is probably ok.... you shouldn't have any issues. Just torque you lug bolts properly.
-Aspire brake swap COMPLETE!
Right. I have some 14" Estrellas with both the Festy and Aspire bolt patterns. The center hole is much larger than the Festy's. Doesn't matter.Originally posted by ejp2fast View Postthat center bore being larger is probably ok.... you shouldn't have any issues. Just torque your lug bolts properly.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
