Sway Bar-Front AND Rear
I hope I dont get Monsoon'd for this, but, the rear bar is great and all, but is there a way to get real brakes back there too? And keep the stock pattern...?91GL BP/F3A with boost
Originally posted by bhazard View PostI hope I dont get Monsoon'd for this, but, the rear bar is great and all, but is there a way to get real brakes back there too? And keep the stock pattern...?
Good question. I'd like to know too.Festiva: Because even my dog can build a Honda.
Its tough to do anything other than give an award.
And add that these wheels are the same bolt pattern as a Festiva. So MAYBE the brakes from these cars could be swapped. But Im not sure. Something to do some more searching on though.
1989-81 Mazda- 323/GLC
1985-84 Mazda- RX7 GSL-SE 14 x 5.5 40mm offset
1991-86 Mazda- RX7 14 x 5.5 40mm offset
1987-85 Mazda- 626/MX-6
1994-91 Mercury- Capri 14 x 5.5 45mm offset (16 holes)
1994-91 Mercury- Capri 15 x 6 45mm offset (3 curved spokes)
1994-91 Mercury- Topaz 14 x 5.5 (16 holes)Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
Hmm... BF 323 maybe?
According to rockauto...
Festy drums are 7.63" OD (LOL)
'89 323 sedan and hatch are 8.9" OD
'89 323 wagon are 10" OD
'87 626 are 10.23" OD
'95 Aspire are 9.65" OD
The thing is what would fit on our spindle, or what spindle would bolt on to our beam.91GL BP/F3A with boost
With our luck. Probably none without some type of enlarging of holes or something.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
The thing is what would fit on our spindle, or what spindle would bolt on to our beam.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Today I finally put on the Aspire front sway bar I got a couple of months ago at the JY; I forget if it was from an auto or manual, but it looks just like the one on my manual Aspire. I mounted it right-side-up BTW.
Someone suggested shimming up the radiator for clearance. I thought this was to prevent the bar contacting the rad, but on my car the Aspire bar contacts the lower rad hose. Tmw I'm going to drain the coolant, remove the rad hose and cut off 1/2" from the end that connects to the radiator. This will give the clearance needed.
As far as clearance from the transmission crossmember, I'm not yet sure it contacts it, but if so it's just barely. I might do some shimming with washers to solve that issue.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Are the bolts long enough to shim with washers?
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
Originally posted by Festiva_tunner View PostAre the bolts long enough to shim with washers?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
