can't hook up! need to find wheels
  • can't hook up! need to find wheels
    Ok here it is, I have 13x5.5 inch wheels on The festiva right now. Can't hook up at all. I want to get new rims but don't know what size yet. I am going to up grade suspension and use the 35mm lowering springs. also am thinking of buying the FMS body kit. I was looking at the Konigs with some good rubber but don't know? what size rims can i fit and where to get them. Thanks
    1989 B6T Festiva...... it is a constant work in progress.
    sure
    Ok I know this sound like a dumb question and people will just tell me to research. Thats what this site is is research. does someone have festiva bolt pattern specs? thanks please reply
      After your Aspire brake and suspension upgrade, your bolt pattern will be 4 X 100mm. Offsets should be between about 38 and 45 mm positive. You probably shouldn't go over a 6.5 inch wide wheel unless you want to solve clearance issues. Also, using an Aspire rear strut will give you another 3/4" of inner tire clearance.
      Much of the above can change depending on the stuff you do and use.
      Mounting 175/60s on 5.5" wide Konigs should be fine.
      A set of Konig Theories will handle both Aspire and Festiva bolt patterns, so you can buy them now and then use them after your suspension swap.
      Karl
        thanks for the info, finally someone that has somehting useful to say.
          I just had nothing better to do!
          Karl
