Wheel tire size question.
  • Wheel tire size question.
    I have the opportunity to get some 14" wheels off a Suzuki Swift that I quite like. Here's my question... which would you choose 175-70-13 tires or 185-60-14 tires?
    Overall diameter of the two is very close so that's not an issue for me.
    Thanks for your opinions
    Ian
    I'm hoping you meant 175-70-14. I would go with the 60's myself but....
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      Clarification... choosing between staying with my 13" wheels with the 175-70-13's or going to the 14" wheels with the 185-60-14's.
      Sorry for the confusion
      Ian
        14 with the lower profile
        BPT, G5M-R, BP26 Exintake swap + Fidanza cam gear, NSRT4 FMIC + 2.5" piping, HKS SSQV BOV, Exedy clutch, 3" downpipe + 2" all the way back, Aspire brake swap, KYB GR-2 & FMS coil spring , FMS EURO body kit + Carbon fiber hood, Falcon RTX 15X6˝ + Toyo proxes T1R 195/45R15
          Purely depends on whether you are biased toward better ride or better handling; and weight of the wheels is a factor too, for stopping distance and also how quickly the tire will react to a bump.
          The 14's with tires are probably heavier, right? So with the 60 tires, you get better handling but longer stopping distance--unless you go with an Aspire brake swap, then it wouldn't matter much. The 13s with 70 series tires will give a more comfy ride. I have 70s on my Aspire and they are fine for ride comfort and also corner well, but obviously the 60s would corner a little better--and are still adequately comfortable.
          You can improve the handling with an Aspire sway bar too.
            ^^agreed, I just purchaced a set of the same 323 wheels you have Ian. They are quite light, they make my 13 steelies seem like lead weights.
            -Scott
            Aqua 93 L
            Razor Red 09 F-150 XLT
            White 06 Ford Escape XLT
