Ok i have done alot of reading of others suspension and see that most of every one has to stiff or are using them for the auto x racing. So i was just curious on what rate of spring would be best for a every day driver and usually with two people in(around 275 lbs total) it with a bp swap and will have aspire swap as well. What rate spring would be a best bet?
spring rates
"Best" is relative. I have 200 front, 150 rear and I think thats about just right for a 'sporty' feel and still being a daily driver. Not too rough etc, and still close enough to being the right rates for the GR2s. And it handles great!~Nate
Current cars:
FOTY 2008 winner!
Yes you can. But remember that the spring perch on the Aspire struts is about 3/4" higher than Festivas.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
NO! order the proper length spring and rate to achieve the ride hight and quality you want. aspire springs with 1/2 to 1 full coil removed in the rear does the trick for most ppl.Trees aren't kind to me...
Ok...I want to be a little lower, but not a whole lot to where i rub all the time or when i hit big bumps but want to be lower. Also my dad said not to cut the springs because of how it weakens them. So what height of spring would be recommended that i should use? I was thinking of a set of lowering springs from a civic.
like these
If you haven't yet read the part of that thread on coil-overs. I miss typed earlier, i have 150/125 springs in 10" length. If your going to use aspire struts you will want shorter springs for at least the rear (8" or so should be good if you don't want to lower too much, 6" if you want to be able to lower more).
The civic coilovers will be like riding on rocks, gotta replace the springs with decent ones of the right rate.~Nate
Current cars:
FOTY 2008 winner!
Really ok. In your thread you said you will have to remove the perch on the rears. I was to get stock ones and springs like you did should i cut the perch off?
What car where yours for?(springs)Last edited by hofficergrover; 01-28-2010, 09:17 AM.
Springs are not for a specific car... you buy them by what rate/length you want.
I didn't cut the perches off for a while, you only have to do that if a) you want to run a wider tire that is rubbing them or b) you have 10" springs and want to lower it more.~Nate
Current cars:
FOTY 2008 winner!
Ok cool thanks
What diameter of spring would i need?
I really appreciate it.Last edited by hofficergrover; 01-28-2010, 02:35 PM.
