All I could find was Quaddawg's 323/Mirage combo and FastivaB6TG25MR's Camry/Maxima set-up. Has anyone else done these, or have done differently? And yes, I did search but nothing really came up.
Upgrade stiffer struts: Anyone else do it?
Current cars:
2002 Toyota Tundra - V6/Auto/2WD - The Tow Vehicle.Tags: None
no one has ever tried anything else?Current cars:
working on 5th gen cavalier rear struts... (spring time)Trees aren't kind to me...
do you mean 3rd gen? (1995-2005?) (Via Wikipedia)?
EDIT: I've seen pics of 240SX rear struts, I'd love to compare them. I dont need the spring hat to work because I'm chopping it off for the coil-over conversion sleeve.Last edited by chrisofna; 02-19-2010, 01:48 AM.Current cars:
yeah... the last ones before switching to the cobalt.Trees aren't kind to me...
Was told by a few folks here and by a Monroe rep, that the Aspire struts are stiffer, as the Aspire weighs more, and are a direct bolt in.Dan
How close-looking are they? I might have access to a parts car here.Current cars:
Originally posted by drddan View PostWas told that the Aspire struts are stiffer, as the Aspire weighs more, and are a direct bolt in.Current cars:
Originally posted by chrisofna View PostHow close-looking are they? I might have access to a parts car here.Trees aren't kind to me...
Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Yes... Read the First post:
All I could find was Quaddawg's 323/Mirage combo and FastivaB6TG25MR's Camry/Maxima set-up. Has anyone else done these, or have done differently? And yes, I did search but nothing really came up.Current cars:
Originally posted by FestYboy View Postyou'll have to grind a few thousands off the lower sleave, but other than that, should bolt in with your prefered coil-over, or mod the perch to hold the stock springs (j-body springs are larger in dia.)Current cars:
weld the top and bottom of the holes to make a slotted hole that fits the stock bolt.Trees aren't kind to me...
my festiva has apex suspension meant for VW, the holes needed to be slotted though
