Here is an update on my assembly. Put the rear suspension in. I'm using an aspire rear beam with KYB GR2 struts and FMS lowering springs. What a pain this was. I had 2 aspire rears and my festiva rear. All the strut mount bolts broke, on all 3 beams. I had to cut all the struts off the beam I used and remove the bolts from the beam. Then I had to buy new bolts. I guess this was best anyways. When you assembly the struts USE antisieze.
Now on to the front. Similar situation there, the control arm nuts spun inside the frame so I'll deal with that next.
Note that I missed the front edge of the bumper cover when I painted. The way I had them position I missed the edges with the gun, I'll touch that up later.
