aspire/festiva coil spring question
  • aspire/festiva coil spring question
    ok so from what i have read the aspire springs are a little stiffer and a little lower than the festiva ones (one of the reasons people like the swap) but my question is about the festiva/aspire fms springs. is there a difference between the tow or are they the same? if i bought the fms aspire springs is the spring rate different (maybe stiffer) than the festiva fms springs?
    anyone have any thoughts?
      The fms springs have a different part number.
      I would think they would be a different springs.
      Can't see them stocking same spring under 2 different numbers
      Jerry
      Team Lightning
      Owner of Team Lightning
      93 L Lightning. BP
        cool this is good info thanks, so the kyb's have differently dampened as well? rite? and the suspension alone (without the knuckles and rear beam are direct bolt on rite?
          If you are buying the springs from FMS, just give them a call and ask what the spring rates are for each set.
          Oscar
