I have bad strut bearings in front, so I'm putting on my Aspire front suspension early. This week.
I also want to put on my rear axle, but it has a problem:
One lower shock bolt came out easy. The other one kept turning, real hard, with the shock leaning over. The metal sleeve had corroded onto the bolt and refused to come out. Unfortunately, I kept turning it and actually pushed the inner threaded captive "nut" (inside the trailing arm) farther into the trailing arm. I had Midas cut out my shockbolt and sleeve, and then I thought I'd put in a short bolt and pull that threaded section back into place. That didn't work. The bolt doesn't catch.
I have an Aspire rear axle that doesn't have one shock mount.
Here's my plan:
1. Take off the brake drum assembly.
2. Drill hole, maybe up to 3/8" in diameter, on the other side of the trailing arm for access. A hole in this area should not matter.
3. Put in punch and use hammer to whack that threaded bit back into place.
What do you all think?
Any better ideas?
Here's my plan:
Any better ideas?
