so i bought some jdm 15's they are 6 inches wide with a 40mm offset and i would like to keep the rubber around what stock is but the whole system of tires confuses me. I tried using the calculator and all the numbers i put in didn't work out. If someone has 15x6 i would love to know what size rubber you run.
just bought some 15's
195/50/15 will be the closest you can find that are EASILY attainable (there are 195/45/15 available but only one company makes them.) also search onlinetires.com they have 165/50/15s from Federal (i'm looking into these myself)Trees aren't kind to me...
195/50/15's here-Greg
Redneck Engineer
FOTY - '09
The lower spring perch will rub a little. The Aspire strut has a "higher" spring perch.
You'll have to come to Westiva2010 and show off the car with the new wheels and tiresIan
sweet, looking good hope to see you out at the westiva meet
Mike, AKA the sasquatch
sweet rims, all it needs is a little rubber...
-Aspire brake swap COMPLETE!
