read that u could run escort brakes on aspire spindles,but would it be possbile to swap all escort parts onto a festiva? im on the lookout for a EGT to take everything from for the bp swap and trans,and figured if i could use the brakes that would rock as well.
brake question
Do you mean hubs?
Festivas have spindles in the back and hubs up front!'93 Blue 5spd 230K(down for clutch and overall maintanence)
For the fronts, the only thing that you can use with the aspire system is the escort caliper, and I am not sure about the rears. If you use the front escort calipers I think you need to have 14" wheels.Last edited by timmay89; 05-26-2010, 07:48 PM.
