Searching thru posts(yes the search function!) and seeing all the posts about front Rio struts and Aspire struts, I got to wondering: Between these struts, is one stiffer than the other or about the same? I just scored 2 front Rio struts for $32 at PnP yesterday during their 1/2 off Memorial Day sale!
I may go back and get some Aspire struts too as I need them for the rear and i'll probably take the front while I am there.
Edit: I also found a secret to removing the Rio struts without having to "cut" the little linkage rod. If you take all the upper and lower strut bolts out first, then twist the strut and "bind up" the linkage rod, giving it a good hard yank when in this bind it will just pop off from the strut, leaving just the little "ball" that the rod attaches to on the strut. Much to my pleasant surprise while sawing on the first one! After sawing about half way thru I thought maybe I could bend and break it at the saw slot, and when I tried, the whole rod end just popped off the attachment ball. Popped off the other one no problem.
