Ok seen that some guys are running rio struts. Well i was thinking about running rio lowering springs on aspire struts, but would the rears fit? Because i found a kit for all four corners and it is very cheap. Any one know if they would work on the rears. Also how tall are the stock rio springs?
lowering springs
The back end of a Rio is quite different. I'm not sure the rear springs will work.
Rio springs are taller. Lowering springs for them might only give you stock ride height.Last edited by JPT; 06-15-2010, 09:42 AM.Festiva: Because even my dog can build a Honda.
Yeah i was thinking that, but thought i could get them since they are really cheap and are zenn brand. I don't know if they are good brand but seen allot of col bolts running them and some mustangs. Are the springs like bigger diameter than the aspire?
I'm ok with stock height just want them to look nice and the stock ones are not very nice.
hi guys,
i bought b+g lowering springs.... it gave my kia pride sedan 2 finger gap drop.=)
kia pride beta gtx (4 door sedan in Philippines)
1.3L carb engine
15" mags with 185/45/r15 tires
Kia pride 2 door
1.1L carb engine
all stock=))
-Aspire brake swap COMPLETE!
I thought about Kia Rio lowering springs, too. For under $100 for all four (can't remember exact amount, but could be less than 80), you shouldn't mind not using the rears.
I doubt very much Rio rear springs would work. VERY different rear end.
I haven't done it yet, but I'm 99% sure Rio front springs will fit Festiva and Aspire front struts. I have them but I just haven't taken them apart and tried. Look at my pics in one of the other Rio suspension or brake threads here. Side by side comparisons.
FWIW, you may only want the front lowering Rio springs anyway.
On Big Blue I only run the front FMS lowering springs, gives me the handling I want and a slight "down hill" rake to the car, but with the regular springs in the back my load capacity, such as it is, is not encumbered by the lower springs.
Meaning, I can put an engine, transmission, and various other heavy parts in the back and not worry about bottoming out.'93 Blue 5spd 230K(down for clutch and overall maintanence)
here's the pictures of the lowering springs.... it gave my kia pride 2" fender gap to my tires
*though in this picture im not yet using the b+g lowering springs but the effect is still the same... ill post the pics of my pride with the lowering springs next time....
1.3L carb engine
Kia pride 2 door
1.1L carb engine
all stock=))
thanks for the compliment guys.... visit my cardomain if you have the time and add me up :p http://www.cardomain.com/ride/3870904
@perucho
it's an old stock maybe it's in the shop around 1997 and the owner this is the last set....
i love this springs so much though it cost me an arm and leg but i feel the difference when i compared it to my other friend's pride with honda springs and gas shocks my pride is more comfortable and not bouncy...:p
1.3L carb engine
Kia pride 2 door
1.1L carb engine
all stock=))
