Completed Aspire Swap
  • Completed Aspire Swap
    i finished the aspire brake swap last weekend, i used the front sway bar also. i cut the springs for now, until i can afford coil-overs, the car has the interior stripped and im looking for a b6t donor. found out i already have gr-2's on the rear that was a nice surprise.
    Nice! Your car looks really clean :thumbright:
    -85' Nissan Sentra 5 spd.
      lookin good! you should use bondo restore black on your bumpers and trim link
        About how much did you cut off of the springs? I like the height of it.
        -Donny
        -1992 Festiva GL
        B6D/E-series.
        -1991 GL
        BP/Broken E-Series. Working on G transmission.
        -2011 Mazdaspeed3
          This car is just sexy.
            well this side is somewhat sexy haha, the other side, well you guys aren't allowed to see it yet. haha. i cut 3" off the springs all the way around. it has the aspire wheels on it.
              If only you were on the east coast, I'd have a swap to offer you
              Is this the guide you used for the Aspire brake swap?
                If you're gonna put wider tires on eventually, you will want Aspire rear struts, for the raised lower spring perch.
                  http://www.clubprotege.com/wil/howto/aspirebrakes.htm
                  yep, that's a good list to go by.
                  Walth
                  Festiva #1: 91 Red L 4/5
