Tire/wheel weights
  • #16
    Originally posted by Advancedynamix View Post
    Side note. Alloy space saver spares for a 1986-89 rx7 base model are made by enkei, they are 15" and very light weight. They are also a direct bolt on to a Festiva (4x114.3). I'll try to get an actual weight with spare tire next week.
    Could you also check on the backspacing? IE would they need spacers to pull them away from the struts.
    • #17
      Charlie wrote:
      "Side note. Alloy space saver spares for a 1986-89 rx7 base model are made by enkei, they are 15" and very light weight. They are also a direct bolt on to a Festiva (4x114.3). I'll try to get an actual weight with spare tire next week."
      I've only seen a later model alloy doughnut at the PnP. It was 4 X 108 or 110 (whatever newer RX7s were). I was intrigued and wondered about earlier years.
      Early alloy RX7 doughnuts. Probably something like 14 or 15 X 3.5 or 4" wide. Probably less than eight pounds. You got my attention Charlie!!
      Karl
      • #18
        All RX7 4 lug are 4x114.3 iirc. I also have 14" rx7 4 lug wheels.
        I'll bolt a couple of those spares up to my 89 so you can see what they look like. I have 3 RX-7 spares, waiting for the 4th to make a set for a fuel mizer build.
        • #19
          I didn't get he chance to weigh these, but they are 15x4 with a 40mm offset. They are hubcentric to the festiva hubs. They have 135-70-15" tires on them.
          • #20
            looks awesome. i'd love those exact rims ^
            My Fuel Log
            See post #10 for my tips on fuel economy
            • #21
              at one point, i came across a nissan 16" alloy spare in an awesome yellow but after a search, i couldn't verify what model had them...
              • #22
                Thanks Charlie, they're very nice looking.
                • #23
                  I think 155/60/15" tires would fit on these.
                  • #24
                    which car are these off of? the rx7 rims i've seen in pictures of don't look like this.
                    My Fuel Log
                    • #25
                      Charlie sez they are '86 - '89 RX7 spacesavers.
                      • #26
                        they are to nice for that lol!
                        My Fuel Log
                        • #27
                          Actually I was thinking the same thing. Charlie?
                          Edit: I notice the size is "4-T x 15", where the T probably means temporary.
                          • #28
                            If you think aluminum wheels are light, you would be shocked at how light magnesium wheels are.
                            • #29
                              ^I bought a set once and they ended up being heavier than the steelies I wanted to replace. Not that style, but mags from an old Lexus. Depends, I guess.
                              • #30
                                Just because its says mag wheel does not mean it is made of magnesium alloy. All wheels are alloys. You can call any aluminum wheel a mag wheel. I am sure it has at least 0.2% magnesium. I am talking about wheels where the primary alloying metal is magnesium, at least 90%. For instance, a popular magnesium alloy is AZ31, which means 3% aluminum and 1% zinc. Besides other trace elements, the remainder is magnesium.
