When I checked mine I just jacked the whole front end up and let the suspension hang with both front wheels off the ground. I then took a crowbar (or prybar, or humongous screwdriver) and slipped it in between the control arm and the knuckle near the pinch bolt (the horizontal bolt that holds the control arm to the knuckle). Preferably, use a prybar about 24" to 36" long with a curved (bent) end.
Gently pry the two pieces to see if they come apart some due to a loose ball joint. The ball joint is at the end of the control arm at the knuckle and is held in by the pinch bolt. Any looseness should be inside the control arm socket for the ball joint (if the pinch bolt is properly tightened).
Also check the rubber grease pack around the ball joint--if it is leaking seriously or falling to pieces/dryrotted, you'll want to either replace it with a new rubber cover (available from FMS??) or go ahead and just put on new control arms.
Also just grab onto the control arms (try both ends of each) and see if you can shake it to find any other play (for example the pivot bolts to the body). Before you let the car down, grab onto the tires and shake them too, to find any more play--possibly in the wheel bearings themselves.
That's how I'd do it. Someone correct me if I'm wrong on something.
