Festiva GR2 on Aspire?
  • Festiva GR2 on Aspire?
    Is there any reason I can't use the KYB GR2 struts for the front of a Festiva on the front of an Aspire? I like the GR2 feel better than the Monroes.
    On my Festiva I had GR2s on front and rear, but changed the rears to Aspire Monroes to get the higher spring perch. I think the rear GR2s had a better feel, but I am done with rear spacers. Comparing them side by side, the Festy rear GR2s had a thicker shaft than the rear Aspire Monroes, and different valving too, no doubt.
    I know I'll be stuck with Monroes on the rear of the Aspire, But I thought at least I can get the Festy GR2s on the front. Good idea, bad idea?
    "-KYB GR-2 front, Monroe Sensa-Trac rear shocks (removed Fiesta-spec rear GR-2's to allow fitting larger rear wheels) wearing stock springs (eBay coil-overs removed)"
    I assume you're on FA.com... I'm not, so you might want to shoot that guy a PM to be sure no mods were needed.
    1988 Chevy Sprint Turbo 997cc
      Fiesta-spec struts? Would those even bolt up?
      91GL BP/F3A with boost
        I assume (it's a post from 2008 ) that it's probably supposed to say Festiva, but I'm not entirely sure. Worth asking to find out... even Ford Aspire/Festiva owners mix them up apparently haha.
          Originally posted by Aaronbrook37 View Post
          http://fordaspire.5.forumer.com/inde...showtopic=3545
          Thanks for the info. I'm sure he meant Festiva.
            Fronts should direct swap, rears will have the spring perch lower, but should clear stock 13" tire sizes. def. won't clear 185-65-14's.
            Facebook Me!
              I was pretty sure the Festy GR2 fronts were a direct swap onto an Aspire, but just wanted some confirmation. And I do have the Aspire rears on my Festy for the higher spring perch. My tires are 185/60x14 on AR Estrellas; there is no rubbing going on. Thanks for ur input everyone.
