Yes those will fit, use Toyo 145/45/14 tires for trouble free driving.
He meant 195/45x14. If you want 185/60x14, for example, which are taller, you should go to Aspire rear struts, which have a taller spring perch and clear the taller tires with no rubbing.
You can avoid reality, but you can't avoid the consequences of avoiding reality--Ayn Rand Disaster preparedness
