I pulled my non-leaky BMC(brake master cylinder) off a 97 Aspire with a manual transmission and only 97k miles. When I did, I didn't unscrew the brake lines from the BMC, I cut them about 6" from the BMC and you'll see why later.
When I started the swap on my car, I soaked all the bolts with PB Blaster for about 30 mins before I started turning wrenches. Before I cracked my lines open, I put an oil pan on the ground under my BMC to prevent brake fluid all over my driveway.
First I unplugged the connector to the BMC.
Next I used a 10mm open end wrench to remove the brake lines.
Next, remove the 2 12mm nuts that hold the BMC to the brake booster. Remove your old BMC and let it drain in your oil pan. Put the Aspire BMC in the place of your old one and tighten the 2 12mm nuts back down. This is where the old brake lines still connected to your BMC will help you. Bend them up and try not to kink them while you're doing so. Bend them over and into your BMC to help you with bleeding. Pinch the middle of the brake line you're using so that it cuts off free flowing brake fluid and doesn't suck air back in the BMC.
Fill your reservoir to the full line and lay the lid back on to prevent the fluid from splashing everywhere.
Pump your brakes 25-30 times or until bubbles stop coming out of the brake lines. Go ahead and bend your new brake line very carefully to go into the new top port of your Aspire BMC. You will have to pull the brake line forward a little bit and turn it toward the driver side tire and then down. Take your 10mm bolts loose from the cut brake lines and remove them. Install your existing and newly re-bent brake lines that are on the car.
Last, you're going to bleed your brakes at all 4 corners to ensure proper braking. Your going to start with your passenger rear, then your drivers rear, next the passenger front and last the drivers front. This order keeps air out of lines you have already bleed. Make sure you test to see if you have good pedal pressure before you go for a test drive. Enjoy!
Note: I kept my Festiva brake booster on the car but you can also swap it for the Aspire brake booser. The one from the Aspire is larger and will give you softer brakes.
