Camshaft bore? Crankshaft bore? Lots 'o bores on an engine.
Guess its all boring!
Dan
Well, we're in Custom suspension, brakes and wheels, so the natural assumption is center wheel bore.
Also I'm french, so "I farte ihn yowr general dircechion!"
The reason i'm asking, is that i may have a line on some decent looking 15" dial +40 offset 4X114.3 wheels. They came off a accord / prelude (or so the seller claims) This should be 4X100, but he clearly states the wheels are 114.3's hence why the rock bottom price.
If they're off an accord or prelude then they most likely are 4x114. Also, honda's center bore is a bit bigger than the festy so they will fit as far as that goes
from the sounds of it, he tried to put them on his new honda (4X100) with no success.
Haha, some people don't do any kind of research before just buying stuff and trying to put it on. Oh well, his loss!
Edit: I also remember reading that the miata has one of the smallest center bores at 54.1 and miata wheels fit perfectly on aspire swapped festies. I'm thinking the festy probably has the same 54.1 center bore. Just read that a lot of preludes/civics/hondas center bore is 56.1
The Honda Prelude rims I just got have a 56.1mm center bore and 45mm offset (I'm already pricing spacers).
They're off of an '86 and have a 4x100 bolt pattern.
Festivas do have a 54.1mm center bore.
I used Toyota Corolla wheels on mine, and after an Aspire swap, they fit exactly over the hubs. I would have had to use spacers had I not used the Aspire struts and rear springs, but with the weight of two full size people in the back of the car, it sits level and responds well, with no rubbing. Only bad thing is, it's a bit rough over railroad tracks.
1994, yes. Regionally available. Sorry if I hacked the thread... Just trying to show the Aspire struts remove need for spacers (depending on offset). Thanks, KofKof. It's a Grant Challenger. Wheel and mounting hub $40-$50.
