I want 14"s, but I'd rather not have the jacked up look. Plus my car is mostly stock, so not much power getting to the road as it is. I've found some cheap tires that keep(VERY nearly) the same overall diameter as stock, so I thought I'd share, as I see most guys running tall ones that have bigger wheels.
185/55/14 Marangoni VERSO. Shipped from tireeasy.com will be $240.00.
Not bad IMO. Obviously I'm not caring about the rubber compound or tread pattern, and really anything in 185 will be worlds better than the 155s I have now, so it doesn't matter anyway.
If I've done the math correctly, I'll only be off by .2" total diameter.
21.7" - 155/80/12
21.9" - 185/55/14
22.7" - 185/60/14
21.7" - 155/80/12
21.9" - 185/55/14
22.7" - 185/60/14
JAMAICA TO THE WORLD
The other two sets just "appeared" on CL. The last, cheapest & lightest set was only a few blocks away!
