Lucked out at PnP this morning. Found a ,96 Aspire with only 129,000km (80,000 miles) on it with everything still there. The brake pads even look fairly new on the front. Didn't get the rear axle but will go back for that shortly.
Almost screwed up though... took the cotter pin out of the tie rod and then said OK that should pop out now. Started beating on it with the hammer and couldn't figure out why it was coming apart.
It was then I had my "DUH" moment and realized I forgot to undo the nut! I was fortunate that the nut came off at all with the amount I had beaten on the tie rod.
Hope to have everything together in the next few days along with the new inner and out tie rods. I'm hoping that my front end problems will be solved with all this work.
Will be keeping you posted.
