the only place i rum when loaded down is the rear bumper support bracket (thin little rod that holds the outer lower corners in place).
And your suspension configuration and tire/wheel combo is?
i would imagine you will not have a single issue with the 155s. i managed to stuff 205/50/15 bfg g-force sports on Toyota Yaris wheels in the rear with minor-moderate clearance issues. The entire tread on the tire is tucked inside the fender, so its about as low as anyone would want to run and intend to drive anywhere that isnt perfect roads. I had 195/50/15 kumhos on the same wheels and not a single clearance issue, even loaded down after a jy run hauling a trans, and full aspire swap in the back.
Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
Post pictures here!
(No inapropriate posts - children visit FF.com too!)
that was when i had 165/70/13's with +45 offset (13x5.5 wheels)
because of the offset, no issues
-Aspire brake swap COMPLETE! https://www.wunderground.com/persona...?ID=KOKOWASS38
I wasn't certain which car you spoke of, because I know Scrappy's suspension is somewhat modified as well as larger than 13" wheels, me thinks.
ok, so Steelstiva (Derek) just got some new shoes and was in desperate need of lowering, so that's what we did today. here's the before and after picks (side by side and cropped for easy viewing).
here's the details: 14x6 +35 offset, 165/60/14 federals, stock suspention cut 1.5 coils in the rear and 1.25 coils in the front.
ok, Update: just aligned the car, was toed out a bit and the camber is now on the limits of factory specs (-0.3*) both sides, which is just fine. As Derek left for the night, i noticed that the car had settled even more than the pix show (a few more miles were put on the car to and from the shop). I gotta say, I do good work :p
