Wheels & tires
  • Wheels & tires
    I just found 4 '94 Honda Accord rims94x114.3) with very good 185/70 R14 tires. Any problems mounting these on my '93 Festy with stock suspention? What about lug nuts?
    '93 Green L - ' Tiva
    GD is not a "catch all"... Thread moved to the correct forum.
    Simon - pimptiva.com
      Wheels
      Sorry about that. Just found these for sale. Want to know if theres any issues before I buy.:angel10:
        the 70 series might be a lil to tall but I'm not 100 percent on that
        93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
        RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
        RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
        RJ
          Thanks RJ. What about wheels, lug nuts?
            I've got that combo on my Accord. I suppose I could test fit it on a Festi. I could only do it on the rear though, since I'm in the middle of pulling the engine and don't have the front hubs/suspension mounted up.
              Sorry, my mistake...don't know what I was thinking! haha
              Mine are actually 4x100. They changed the following year. My tires are 185/70R13.
                the pattern is correct 4x114.3 is that 9 in front of the measurement the width of wheel? if it is no way 9 wide would fit
                RJ
                  i have 185-60-14s on the bp festiva at stock height with stiffer springs and they are just slightly smaller then the 185-70-14s and if i had softer suspension it wiuld rub on corners.
                  88 festiva lx, 2.3 turbo rwd swap in progress
                  1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
                  R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
                  00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
                  03' gt, full termi swap 700+ whp build
                  sponsered by,
                  pam pam's junk, dayton OR.
                  Bob's ok tires, salem OR.
                  Clausen Truckin', keizer OR.
                    tires are too tall, run 185/60/14 at the largest, optimal is 165/60/14. should mount just fine, but you'll need a small spacer in the rear to keep from touching the rear trailing arm and the lug bolts MUST be round and NOT conical to seat properly. you should be able to find these at any McAutoParts store.
                      Wheels
                      No the 9 is me not hitting shift, it should be(. lol
                        Wheels
                        Thanks all. Don't think I'll get them. Good price though $175. for all.
