Speedometer after changing rim size?
  • Speedometer after changing rim size?
    I've tried searching the site and google-ing this question, but received nothing, so a thread it shall be!
    If I were to upgrade my rims from the stock 12" to 13" for ease of finding tires, how would I compensate for the un-calibrated speedometer? There HAS to be a way to make it line up again, right? People change rims all the time, so there has to be an at-home solution to this, right?
    If not, can't this be compensated for by buying tires with a thinner sidewall, so the overall diameter is about the same?
    Thanks!
    1990 White L-Plus 5-speed rust-machine
    Scrapped
    1991 Blue L 5-speed
    daily driver, intermittent project
    1993 rustless wonder
    A shell, awaiting suspension, brakes, and B6T
    depending on if you go 13" with low profile tires...the overall diameter may be the same as the stock 12" with a normal tire meaning that you might not need to change the speedometer. even without a low profile tire on the new 13" rims i would imagine it would only be off 2-3 mph and might not pose that great of a problem....i could be wrong
      I just found an ehow article on this that had a bunch of math to do that would give you the right size for the speedometer cable gear. Apparently I need to go to ford to find one, though.
      Scrapped
      1991 Blue L 5-speed
        Use a GPS, works a like a charm, no matter what wheels and tires I use.
          Easy tool to compare tire sizes.. no math for you to do!
          Even tells you how far off your speedometer will be.
          -Zack
            165/65-13 is the size you want to keep it accurate.
            91GL BP/F3A with boost
              I've bookmarked this site and use it all the time, you should too!
              Tire size calculator | 1010Tires.com is the largest and most trusted online and retail tire company.
                Great chart ! thanks . I love this kind of stuff, it can be used over, & over. Save in favorites. Another great one Ice, Thanks. Saved it
                '93 Green L - ' Tiva
                  I don't know of any other gears you can get that fit the Festiva trans... best way I know if you reeeeaally wanted to do it would be pull the plastic off your cluster, and mark where the speedo falls at 10, 20, 30, 40, 50, etc. (using a GPS) then use the marked up cluster face as a template for printing off a new gauge face (maybe scan it into a graphics program). I have printed off custom faces, as well as others on here. If you do a search for custom cluster you can find some links to it.
                  No festiva for me ATM...
                    That sounds like a fun modification
                    -Zack
                      It was. I just used the stock protege cluster as the template though, it reads pretty close with 185/60R14s
