i have a front bearing out on my festi so i was thinking about just doing a brake swap? what can i swap with? am i limited to the aspire? can i still use my 12s on those? what do i need off the aspire?
Front brake swap for a festi... aspire?
Go find an aspire in a junkyard, grab the tie rod ends, and the main hub that holds the rotor and the caliper on, grab both those. You can go and put brand new rotors, calipers and tie rod ends, but make sure you still grab the calipers, to use them as cores. While you're in there, might as well grab the sway bar from the aspire too, better handling, grab the front bushings for them as well. Then if you want to swap the back (recommended) grab the whole rear axle beam, and grab the E-brake cable if it's in good shape. And you can't use the 12's, the bolt patter will then be 4x100 instead of the factory 4x114.3. So grab the aspire rims and put some 155/80/13 tires on them. Or search "aspire swap" ...Last edited by 91blufestiva; 07-06-2011, 10:49 AM.-Josh R
You can do the carpi brakes and still use 12in tires but will need the aspire ball join lower control arm and the hub and caliper and break hoses off the carpi and i think the aspire outer tie rod or a escort gt one. And i think that is it but not for sure so any one else chime in and correct me if i am wrong or add the what needs.
Originally posted by 91blufestiva View PostGo find an aspire in a junkyard, grab the tie rod ends, and the main hub that holds the rotor and the caliper on, grab both those. You can go and put brand new rotors, calipers and tie rod ends, but make sure you still grab the calipers, to use them as cores. While you're in there, might as well grab the sway bar from the aspire too, better handling, grab the front bushings for them as well. Then if you want to swap the back (recommended) grab the whole rear axle beam, and grab the E-brake cable if it's in good shape. And you can't use the 12's, the bolt patter will then be 4x100 instead of the factory 4x114.3. So grab the aspire rims and put some 155/80/13 tires on them. Or search "aspire swap" ...1988 Chevy Sprint Turbo 997cc
I recently did the Aspire swap and initially made the mistake of using the Aspire lower control arms. They move the front wheels out too far which thoroughly messes up the caster/camber and reduces the tread count left on the tie rods (about 1/2 inch less each side). Stick with Festy LCAs (which also happen to be cheaper) but make darn sure you use Aspire tie rods. There again they may 'look the same' as Festys but aren't; seat taper is different.
It's spectacular to discover how many tire and rim combinations there are for 4x100 bolt pattern 2 1/8" hub and you will never regret having superior handling and brakes. Also you will not miss have to run wheelbarrow tires either.
