Originally posted by mdutton
need to gain ground clearance on festiva
Aspire/festiva strut bushings are rubber. Rio strut bushings are bearing style and can be used in conjunction with festiva/aspire struts.-------------------------------------------------------------------------------------------
My Musica! Click me!
The top mount doesn't directly swap between rio and festy/aspire struts, but if you search you can find the fix to make them work, i believe it's just a spacer or washer that's needed. The strut rod on the Rio strut is thicker.Originally posted by Charlie1717 View PostAspire/festiva strut bushings are rubber. Rio strut bushings are bearing style and can be used in conjunction with festiva/aspire struts.
all factory aspire and festiva top mounts are rubber bushings. all factory aspire and festiva top mounts are a 2 bolt type. all 94-97 (american) model aspires use the same factory struts/springs respectively.Originally posted by mdutton View PostDrddan what i forgot to ask was what did you do for the strut tower bearings? are not all aspire tower bearings 3 bolt type? also are the aspire tower bearings a bushing or are they the bearing type? What years of aspire can be used are they all the same no matter what yearLast edited by zoom zoom; 11-09-2011, 11:58 AM.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
