all stock stuff
using the stock stuff i went to the local speed shop and found these for the lca to body
they were too log so i made a ghetto lathe with a socket driver and a drill.
the bushing out of the bag is on the left and cut one is on the right.
i didnt get a pic of the box the bushings i used for the sway bar to lca bushings but here they are
i cut the nubbin off of the end
using the drill bit to center the hole saw i resized the center bore to fit in the lca
i had to double up the collars on the lca to chassis cause they werent thick enough.
