Axle cheat sheet
  • qroger
    replied
    Halleluja! There it Is! Zoot Allors! Thanks so much to all. The final, (I hope) piece of the puzzle to get the Protege motor into the Festiva. (3 years in progress, lol)
  • nitrofarm
    replied
    Thanks Gents I'm @ work and have no access to the file.
  • william
    replied
    Your welcome, I've had it saved to my phone for years lol. Easier to find then looking in the fourm when in the junkyard.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  • w4rkry
    replied
    Thanks for the Save William! I have edited the OP with the new image.
  • william
    replied
    Had it saved
  • Team Lightning
    replied
    Se if you can bulk download the picts in that directory.
  • w4rkry
    replied
    Originally posted by nitrofarm View Post
    I guess I dont understand... I can log onto the site AND view all my pics except that sheet. It has a message that directs me to a paymant page...
    Oh :/ That sucks. Usually they let you view all of them but don't allow you to share them. Do you have the original stored anywhere by chance?
  • nitrofarm
    replied
  • w4rkry
    replied
    Photobucket wants money to 3rd party share this Chart... They obviously count how many times its been viewed. And then lock it up so it cant be viewed without payment. None of my other pictures on Photo Bucket are like this. It wont even let me view it.
    If you can log into photobucket and find it, I can re-host it and fix your dead links.
    I can copy your link for you as well if it helps.
  • nitrofarm
    replied
  • bhazard
    replied
    Originally posted by qroger View Post
    For some reason I don't see the cheat sheet, nor a link. I am searching for the axle that will fit between a F5MR, (1990 Protege) to the Aspire hub swap, on a Festiva. I believe that will be a 24 spline x 24 spline.
    Festiva automatic axles
  • qroger
    replied
  • lessersivad
    replied
    Originally posted by Twistiva View Post
    nitro -
    OK, so the RockAuto axle (Empire) that is only 1/16" longer will work, but will the O'Reilly (Precision....longer than OEM by 5/16") axle work, too?
    Just curious....
    Well I took a chance and bought a Precision shaft for the passenger side of my '93 w/5 speed from O'Reillys.
    Yup the specs show 34 15/16", BUT it also shows the metric length which is labeled as 881 mm.
    Sooo, I did the math and 881 ÷ 25.4 = 34.685. Now 11/16 is .6875.
    I compared the new shaft directly beside the original and if there was any difference I sure didn't see it.
    Even the 'puter screen at O'Reillys showed the same measurements so I thought I'd simply take a chance and compare before installation.
    Hope this helps.
  • nitrofarm
    replied
    LH Aspire from NAPA pn 95-7194 it measures 24".It will work as long as you get the correct length for the RH side. You MUST recenter your drive train after changing your axles. This is recommended after any axle change BTW. Its easy to do and it will guarantee that you dont get bind-age.
  • Twistiva
    replied
    IF that axle truly measure's 34-15/16" I wouldn't use it in a Festy. Its to long,but it would be ok for an Aspire.
    Just curious if you have NAPA's in OK? They sell a really great LH axle FYI...
    nitro -
    May have to get the NAPA LH half-shaft after all. I bought a new L/R Empire (EMPI) set from RockAuto and they sent me an e-mail while I was out of town saying the L one I ordered was replaced for one that is 1/8" longer (24" vs 23 7/8").
    Your chart says get 23 7/8". Will a 24" LH half-shaft work or not???
