i was working on a 2000 civic and notice a 2 piece control arm.
control arm brace idea from a civic
I noticed the same thing on Friday replacing a wheel bearing on an '02 for a guy at work. I'm stocking up ideas for when/if I build another performance festiva. Have four right now, all but one is one the road, and that one will be tomorrow when I get to the tag office. But still all of them are B3 lol.Last edited by htchbck; 12-11-2011, 07:11 AM.No festiva for me ATM...
i am because the lower arm looks similar to the festy's and the gap between the brace and the lca looks to be just enough to accommodate the sway bar bushings.
im very interested in this cause when i launch my front wheels move forward even with my poly lca bushings. maybe i just need to make some sway bar bushings and get to a dyno so i can get a better look at whats going on.I know its a piece of crap but im still faster...and its 100% legal!!!!!
Wouldn't it be nice if you could delete the stock sway bar and adapt theirs! The shorter/thicker bar would probably help alot with keeping the weight distributed.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
enough stock parts... someone needs to make some "proper" controll arms... ones with heim joints and chromoly tubing.... like so...
they look awesome and are a wack load stronger than anything offered from the junkyard...
Mike, AKA the sasquatch
I've wondered if it would be possible to use a length of aircraft cable to keep the LCA's from pulling forward on launch. What if you attached one end of the cable to an eye-style bracket that would attach to the excess threads of the sway bar that stick through the back of the LCA. On the other end, you could maybe attach it to a bracket welded or bolted to the front subframe behind the wheel. With the proper pre-load, the cable would be in tension during launch but still allow the LCA to articulate up and down. Plus, it would be light and easily removable.
I've never actually looked at it close to see if it's feasible, and it may not work.
It was just a thought I had.........which contrary to what my wife says, does actually happen from time to time.Brian
the cable you suggest would work to a point, but only in a straight line. you'd loose a great deal of turning capacity because the wheel will contact the cable in a sharp turn.Trees aren't kind to me...
I think that was his whole point though... it being easy to install/remove so that you could drive to the track, put it on, race, take it off, and then drive home. But it would be a pain making more than one pass though because you'd have to take it back off to line up for your next one . Unless you have three or four buddies at each end of the track to pick the car up and turn it aroundNo festiva for me ATM...
Originally posted by FestYboy View Postthe cable you suggest would work to a point, but only in a straight line. you'd loose a great deal of turning capacity because the wheel will contact the cable in a sharp turn.
Like I said, I've never really looked at the front suspension close enough to decide if it would be feasable. With all 40WHP I currently have, traction is not much of an issue, LOL.Brian
