Can 114mm rims be used on stock Festiva hubs that are 4.5"? I just changed the clown car over to 13" metro rims and now have a lead on a set of 114mm 13". Pick them up mainly for the tires but maybe use the rims also.
114MM vs 4.5"
X3 for 114.3mm = 4.5". So, yeah they'll fit. But like the last two, check width and offset more closely than the bolt pattern.
I have American racing 14" (x6") Estrellas, with a 35mm offset. I have 185/55/r14 federal tires. This set up is the only set up I've ran on 14s, I don't know on other size tires, that hasn't rubbed ever.Fesdiva is it's new name since she's acting crazy- 92 L
That type of deal, you buy them no matter if they fit or not. Worst case scenario you resell at a higher price.
FYI, Stock Festy center bore is 59.6mm. The center bore on most wheels with a 114.3mm (4.5") bolt circle will be at least this big.Festiva: Because even my dog can build a Honda.
- Likes 1
