Not safely. You can borrow one from Autozone. You have to put up a deposit but it's
refunded when you return the spring compressor.
Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
well going good so far got the rear springs out didnt take long either with no knowledge on suspension took me about 45 min with taking time to find blocks
89 festiva all of a mighty 1.3 Tha Black Bullet and good ole casper got casper when I was 15 and loved em ever since
Festyboy you said that you can cut 2 in the front an 1.5 in the back ...how much does this lower the car ? I'm on stock 12's right now but may go 13 or 14 later on
before:
after (before it settled and this is only one coil out all around)
i figured these tires be ok lol and they came out fairly easily i had to let down jack and it came rest of way out but other then that no problems i got a question what the easiest way to adjust my e-brake has enough pressure just to keep car from rolling barely when im on hill she starts to roll
there's a 10mm nut at the e-brake handle that can be tightened, but i strongly suggest that you make sure the actuator arms at the drums move freely before adjusting the cable. 10 times out of 10, the actuators are frozen and that causes the issue you describe.
alrighty the handle is tight to i forgot to put that i will scope it out while i got all the stuff out of my way i will drown it in pb blaster
