Did you get your rear brakes working nicely? If not, I highly recommend you take them apart, free the actuators, reset the self-adjusters, check the shoes (or put in new ones), check the wheel cylinders, etc. May as well do it while you have it up.
Might have to soak the actuators in a can full of PB Blaster. That's what I had to do once. After it soaks for a few hours (or days!) then take it out and whack it against something hard back and forth until it frees up. Then grease the pivot real well before reassembly.
Keep in mind Aspire rear drums and axle are so much nicer.
