A family member just bought a scion with optional wheels and found out since they don't get a credit for the steel rims they kept them. Well they only took them and the hub caps since they paid for them. I was wandering they are 4 X 100 and 38mm back spacing 5.5 inch wide. Well I can have them if they will work for my aspire brake upgrade and I have 2 question's. Will they work and what size tire to clear and try to keep the speedo close to correct?
scion wheels
they'll fit just fine, but you MAY need a hub-centric ring or have the rims shaved a little to fit the hub.
what's the rim diameter? if it's a 15" go with a 195/50.Trees aren't kind to me...
If that's Toyota brand it should have the same bore as the Aspire and you won't need the rings.
