FMS springs
  • FMS springs
    I can't remember which are front and back? There is a taller spring with more coils and a shorter one with less coils. Which is which??:cry_smile: I was thinking the taller one is rear but not sure.............................
    93 GL modyfied!!!
    :fish:
    IIRC, mine actually had "front" and "rear" printed on them in white. It was very hard to see, even on brand new springs.
      Looked I don't see any markings
      93 GL modyfied!!!
      :fish:
        I knew I went through the same thing......
        Found my old thread where I actually posted which was marked front and rear..
        Discuss improvements to your Festiva or Aspire in the handling, braking, wheels and tires areas.
          my stockers are taller, smaller in diameter, and smaller wire diameter in rear ?
            Taller more coils are the rear ..
            New build on the way .
              well if that's the case, why does Scrappy bottom out so easily with just one person in the rear? (note: according to the thread, i have the springs on backward, stiffer in the rear).
                Ok taller ones in rear.
                93 GL modyfied!!!
                :fish:
                  If I knew you needed pics I could have got them last weekend.
                  I have a pair for the rear as I only installed the front and I liked it that way.
                  So I have a pair of never installed rear FMS springs to get pics and show the markings.
                    Would you sell the rears?
                    '93 Green L - ' Tiva
                      PM sent.
                        Im just going by the way they were installed on my car when i got it . It might be incorect .
                          Rear springs should be thinner diameter in cross section.
                            Brian,
                            The tall springs are the rears!!!
                            Chuck
                            91 GL -Ol' Rusty
                            93 GL - Lil Red
                            91 L - Tweetystiva
                              Originally posted by hotfordcat View Post
                              Brian,
                              Okay then its correct .. thanks
