Hi everyone,
I've been lurking about for a few months trying to plan out my Festiva build and finally have enough time and money to get it started. I'm mostly going for a competitive autocross car that is still street-able enough to drive to work so for now I'm thinking something like this
Brakes (100):
Aspire sway w/ EGT master cylinder
Wheels and tires (300 to 400):
cheapest 15" rims (preferably aluminum) and 195/50 or 205/50 tires depending on budget
Suspension:
Front (150):
Asprie sway bar, complete Rio struts, mounts and springs (with some coils cut).
I would like to run adjustable mounts if there are any that can be easily modified to work.
I remember seeing a thread about putting ploy bushings in the LCA may also do that if it helps alot.
Rear (150):
Rio springs (cut to be level with front) on either Aspire Monroes or struts form a cavalier or accord if they well work with the springs and clear the tires.
Aspire beam
Also thinking possibly strut tower brace and threaded rod mod (if possible with the Aspire beam?) to help with rear stiffness. Its my understanding that on front wheel drive cars it is best the make the rear as stiff as possible (without causing yourself to spin out all the time) to help with traction while exiting corners.
Engine (rest of money I have):
would like to do a B8-ME if funds permit. if not then I will do the typical simple stuff to try and get a few extra horses out of the 1.3.
A friend suggested I just leave the engine stock and buy coilovers, is this a good idea?
Total I'm looking to spend between $800 to $1000 on all of this.
Does this seem like everything will work? Anyone have experience with autocrossing a setup at all similar? Any advice for me before I start building this?
Any and all help is appreciated.
Brakes (100):
Suspension:
Front (150):
Rear (150):
Aspire beam
