hey everyone im gettin these an they come in an off set on 20 30 40mm which one would look the best on Project Doomsday
new rims i want
new rims i want
Frankie
fully custom 88 festy (project doomsday) Febuary in 2012 calander
Blockspire: ken block replica aspire
AdvancedDynamix: "If you put the same kind of effort into your engine that you put into the rest of the car, well... it'll be epic". thanks man
http://www.facebook.com/#!/profile.p...00000110128487Tags: None
typicaly a 30 will work best, depending on width of course.Trees aren't kind to me...
Originally posted by iceracerdude View PostThose look scary expensive! Very SharpFrankie
Originally posted by FestYboy View Posttypicaly a 30 will work best, depending on width of course.Frankie
Very nice rims. I can't wait to see 'em on your car.In love with a MadScientist!:thumbright:
a 15x6.5 with a +30 offset will fit easily, but you'll have to play with the fender lip just a little.Trees aren't kind to me...
did i mention raceland coilovers.....Frankie
still gonna need to massage the fender lip...Trees aren't kind to me...
what about with a 20 offsetFrankie
then you'll need flares, as a +20 will push the rim 10mm further out as opposed to the +30, and the +40 will pull the rim IN 10mm. with the shape of the rear axle trailing arm, and 15" rims, you may be able to run the +40 offset without the need for spacers in the rear (5mm)Trees aren't kind to me...
ok so to run a 40 off set i could run them but i would need a 5mm spacer??? or could i make these work cause i double check an these ONLY come in a 40 offset
Frankie
