A question for you guys who run Honda VX, HX, Del Sol or other stock 4 X 100mm pattern Honda rims on your Aspires or swapped Festiva hubs:
How do you mount your Honda wheels? It seems you are doing it "lub centric" and using conical bolts or lug nuts to carefully center the wheels on the hubs. How hard is it to do this and do you ever have to redo it when you get an imbalance at speed?
I'm just wanting to know what to expect when I get my own VX rims ready to run.
I expect lug studs with nuts would be easiest but I'm not sure I'll go that way so soon.
(My VW rims have custom steel center rings I had made so they bolt up easy with stock VW ball seat lug bolts, and I used plastic hubrings when I ran my two Estrellas up front for a few weeks. When I will run any of my Mazda rims I won't have to worry since they'll fit the center hub perfectly just as my Aspire rims do.)
Thanks,
Karl
Thanks,
Karl
