Originally posted by Bert
Aspire Rear Beam Swap
Wheelbarrow? I want to keep these :cry_smile:'88 Festiva L, stock carby engine (with exhaust upgrade), 4 speed tranny. Aspire Struts and Springs, Capri 14" wheels, interior gutted, battery in back
'92 Geo Metro XFi
'87 Suzuki Samurai
'85 F150, modded 300cid
1/10 of an inch is maximum error tolerance, this is what most body shops will call good for frame alignment. 1/10 is very much the norm.Originally posted by Bert View Postwould have ever noticed or could be bothered at the time) or maybe a 3/32 (namely 1/10 inch!) error tolerance on Festy bodies combined with a similar 3/32 error on Aspire brackets
Does anybody know what it would take to make an abs aspire setup work on a festiva (Don't care about abs, and don't want to do the work to swap it on to my car). The only aspire around here right now is a ABS 4door.
rockin86ranger: you don't want to get involved with trying to retrofit ABS. Just as much work, or more, as trying to put in power steering. As to using an ABS fitted car to do a Festy swap there should be no problems. Just snip off all the ABS lines and affiliated junk. My Festy has ABS-derived Aspire brakes.
Hey zoom-zoom, I hear ya. "Beauty is in the eye of the beholder". I suppose I should be driving with a bag over my head everytime I step into a Festy too.
The guys that tried this and failed went clear across the beam. Go with 2" squares, the first one centered. Skip 2", then add a 2" square on each side. Tune the rear suspension to balance the front, by adding or removing squares. Maybe you could unbolt the trailing arm attachment brackets to gain access for welding (or cutting) on the car.Originally posted by Rectilinear View PostAlso, has anyone ever boxed in the rear beam to stiffen it further? This is something we seriously considered before install.... Looks like 2" x .125" plate welded to the forward end would seriously add to the stiffness.'88 Festiva L, stock carby engine (with exhaust upgrade), 4 speed tranny. Aspire Struts and Springs, Capri 14" wheels, interior gutted, battery in back
'92 Geo Metro XFi
'87 Suzuki Samurai
yes it can, and no, it's not worth the effort to do it ( the spindles and backing plate are a different bolt pattern than the festy, but they use the same bearings, SO, if you were inclined, you could mod the backing plate to fit the festy bolt pattern and get it done that way).Originally posted by 71Montego View PostCan the aspire drum and axle be added to a stock festiva rear? Is it worth the effort?Trees aren't kind to me...
Coming back to the original question about the brake line connections, I had the same problem with the Aspire rear axle on the Festi. I ended up getting a short brake line tube with male fittings at both ends from Napa or somewhere similar, and connecting it at both ends of the rubber hoses as a splice. Tied it down with zip ties. Worked fine.Thricetiva replaced Icetiva as the new ride
Icetiva-3-race-car-build
Anyone contemplating toying with backing plate modifications in order to use Aspire hubs and drums on a Festy trailing arm would be better off just finding an Aspire beam in the first place: much less work.
Could be (in the absence of donor Aspires) adapting backing plates is a decent way to try to install Rio rear brakes though. That whole structure (with exception of the brakes) is quite a bit different but at least the front wheel brake and suspension arrangement is usable.
