wow that wilwood one is perdy. I have used wilwood stuff on other cars. Only issue there is maybe having to get two wilwood rods to make it work because the chances of it using a fox body part i actually have here is remote (I've owned close to 10 foxes since 1994)
If your brake system as a whole is healthy stop and go traffic will make your passenger get mad at you for braking too hard, and would make everything at speed even more predictable, which i personally want with a festiva. I want it to behave the same engine on or off--like a go kart--for gas nerd hypermiling OR intense mountain driving. A bonus of doing this is you will bleed your system again when you are done so even if you thought it was fine it may work out inherent air that you wouldn't notice with power assist.
